Bobs Ten
Date:  2-25-2018
Number of Hours:  2.70
Brief Description:  Install Aerosport Panel
1412 - 1654
I found that the right side panel was binding during install. Cause was two miss drilled holes where it attached to the tunnel cover. This was fixed and the armrest was positioned.
Install Aerosport Armrest.
Trim forward end of armrest flange to fit.
Trim aft end to fit over tunnel cover.
Measure and drill forward fuel selector hole for reference.
Using strap duplicator, mounting holes were located and drilled.
Holes were final drilled and armrest installed to verify fit.
I found that using a couple of flat head screws to hold the tunnel cover in place while positioning the armrest over those screws was very helpful in locating the remaining holes accurately.
