Bobs Ten
RV-10
Root Fairing Supports
1606 - 1706
Remove clecos from fairing supports.
Remove supports.
Debur holes.
Locate and match drill nut plate mounting holes using #40 drill, cleco as drilled.
Debur holes.
Dimple #19 holes for #8 screw using hand squeezer. I seem to get better results on thicker material using the hand squeezer instead of the DRDT.
Dimple nut plate mounting holes using hand squeezer.
Dimple nut plate mounting holes using hand squeezer. For some reason, I am short K1100 nut plates. I will order more tonight.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
