Continue rigging aileron linkage. With W-730 bellcrank jigs installed, F-1064 pushrods adjusted, applied blue loctite to jam nuts, tighten jam nuts.
The plans say to sweep the controls and check for interference. Noted interference with the control stick base and mount. I think that this will be eliminated when I mount the ailerons, as the control stops for the aileron linkage are dependent on having the ailerons mounted.
Install flap pushrods in flaps.
Mount flaps and verify fit. Both flaps needed to be trimmed to fit around the fuselage sides.
Trim flaps using file, drum sander and s/b wheel. A nominal 3/32" gap was left between the flap and fuselage side for clearance.
Raise and hold flaps in full up position, against aft spar.
Adjust and attach flap pushrods to flap torque tube bellcranks.
Verify full motion of the flaps using a 12V bench power supply. No binding and the flaps return to full up at end of flap motor drive limit.
