Bobs Ten
RV-10
Tank Angle, Rig Ailerons
1700 - 1930
Match drill tank support angles using #30 drill, cleco as drilled.
Rig aileron linkage per plans. All pushrods were set to Van's measurements, Install bellcrank jig in left wing.
Verify control sticks are vertical.
Fabricate a second bellcramk jig, W730, from 063 sheet.
Install second jig in right wing.
Adjust F-1064 pushrod to facilitate neutral ailerons with vertical control stick.
Total pushrod lengths needed to be adjusted les than 1/8".
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
