Bobs Ten
RV-10
Overhead Console
1200 - 1400 1448 - 1712
Remove console from cabin top.
Cleco console access panel in place, final drill panels and console using #28 drill, cleco as drilled.
Remove all clecos.
Debur all holes and smooth edges of panels using s/b wheel.
Position k1000 nut plates on console and drill mounting holes using #40 drill, cleco as drilled.
Debur all holes.
Machine c-sink mounting holes for flush rivets.
Cleco nut plates in position.
Rivet nut plates using p-squeezer.
Verify required hole size for Steinair vents, 2" holesaw is perfect.
Drill 4 vent holes in console at factory locations.
Debur holes using debur tool and permagrit burr.
Verify fit of air vent by installation.
Determine location for console conduit.
Install conduit in left side of console, using self adhesive tie wrap anchors near the aft.
Lay up fiberglas retention strips near the forward section of the console due to the curved surface. Used 1 layer of 9 ounce cloth.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
