Verify fit. The top aft tank mount flange was not flush with the rib when mount bolts were tightened. Instructions state that a spacer may need to be used.
Tank mount spacer was fabricated from 063 sheet.
Space was drilled for mount bolt and two flush rivets to retain it.
