Bobs Ten
RV-10
Install Fuel Tank Fittings & Pressure Test
1400 - 1700
Install fuel screen fittings using Permatex Aviation #3 on NPT threads.
Install 90 Degree elbow for ER tanks using Permatex Aviation #3 on NPT threads.
Temporarily install 1/8" plugs in fuel drain fittings.
Cap fuel supply fitting.
Cover fuel sender unit to protect from water.
Install Schraeder valve adapter.
Fabricate manometer from 1/4" ID vinyl tubing. Tape tubing along 1x2 pine board. Add red colored water to tube.
Connect tube to tank vent line. Clamp open end vertically.
Mark start location of red water.
Measure and mark 13 1/2" on vertical tube.
Connect bicycle pump to schraeder valve.
Pressurize tank to approximately 1 psi, or about 27" differential between manometer levels,
Spray soapy water on tank and fittings, check for leaks.
NO LEAKS FOUND.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
