Bobs Ten
RV-10
Pressure Test Fuel Lines
1224 - 1448
Fabricate a test valve made from a Schraeder Valve and AN fittings.
Cap tunnel bulkhead fuel fittings outside of tunnel.
Pressurize fuel lines, through fuel valve, one at a time, to 55 PSI.
Check each fitting using soapy water, check for bubbles. Each fitting was examined continuously for 90 seconds for bubbles.
Three of the 8 fittings developed very small bubbles.
Removed leaking lines.
Lapped flare with 600 sp and a -6 fitting.
Cleaned flare and reinstalled line.
Repeated test.
All 8 fittings now show no bubbles at 55 PSI for 90 seconds.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
