Bobs Ten
RV-10
QB Wings HID Light
QB Wings Duckworks HID Light Install
1418 - 1612
Debur and smooth edges and holes of left wing HID mount parts.
Fabricate attach angles for mount from 063 x 3/4 aluminum angle 8" long, 4x.
Drill and cleco angles to light mount using #30 drill.
Install mount in left wing rib bay, using cleco clamps to hold the inboard mount in position on the angles.
Remove mount from wing.
Drill inboard mount for rivets using #30 drill.
Drill outboard mount using #30 drill.
Cleco mount together and install in wing to check fit.
Remove mount.
Measure, mark and cut mount for right wing using left mount for measurements.
Cut right mount per instructions.
Debur and smooth edges and holes in right mount, all parts.
Bend stiffener tab UP per instructions, allowing ballast mounting.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
