Bobs Ten
RV-10
QB Wings - Lights
QB Wings Duckworks HID Lights Install
1306 - 1524
Fabricate accurate template for mounting holes.
Locate mounting holes using template on two ribs.
Drill holes using #30 drill.
Cleco 10-32 plate nuts to mounting holes.
Orient plate nut tabs to lightening holes.
Match drill ribs to plate nut tabs, cleco as drilled, using #40 drill.
Debur all holes.
Rivet plate nuts to outboard side of rib bay using pop rivets supplied, 8x.
Measure and cut mounting bracket per instructions.
Bend UP, the stiffeneing tab on bracket to allow for ballast mounting.
Smooth and debur all edges of both sections of mounting bracket, using bench sander and s/b wheel.
NOTED MISSING PARTS IN HID LIGHT KITS. the 063 x 3/4" angle was not included in either kit. I called Duckworks and they are shipping parts.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
