Bobs Ten
RV-10
Empennage Attach VS, Elevators
1336 - 1536
Final drill bottom holes in VS spar using #12 drill.
Machine countersink bottom holes for AN3 hardware.
Instal hardware.
Match drill remaing 2 holes to tailcone bulkhead using #30 drill. Final drill using #12 drill.
Install hardware.
Bolt VS to front spar attach bracket usinf AN4 hardware.
Install elevators to HS.
Verify elevator travel with no binding, stop to stop. Up stop required filing.
NOTE: In photo library pictures of digital level measurements.
Down travel = 26.1 degrees.
Up travel = 29.3 degrees.
Cut elevator pushrod tube to correct length, smooth and debur edges.
Check total elevator throw. Down was
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
