Bobs Ten
RV-10
11-4.1.3.4, 1.2.3
Empennage Attach
1230 - 1412
Relocate tailcone to lower platforms and check level, forward and aft.
Final drill VSattach bracket using 1/4" and #12 drills.
Attach previously fabricated shims to HS attach brackets using carpet tape.
Locate HS on tailcone and cleco to attach bars using #30 alignment holes.
Match drill HS rear spar and attach bars using #12 drill.
Install aN3 hardware after each hole was drilled.
Fabricate HS positioning jig from 2x4 stock. Locate index mark on 2x4 and aft deck.
Remove tailcone aft top skin center cleco. Replace with screw to obtain accurate measurement.
Measure from center screw to HS outside corners. Initial measurement was within 3/32"
Obtain equal measurements from center hole to outboard corners of 94 1/4". Clamp jig to aft deck.
Match drill HS attach brackets to aft deck and doubler using 6" long #12 drill.
Install AN3 hardware as each hole was drilled.
Verify equal measurement after each hole was drilled.
Remove jig and clamps.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
