Bobs Ten
RV-10
Install Elevator Trim Tab Ribs
1924 - 2024
Check proper foam rib sizing per plans.
Mix proseal per directions.
Apply thin layer of proseal to foam rib surfaces.
Insert ribs into trim tab skins, aligning them with scuffed bare areas that were previously marked.
Position trim tab clamps directly over ribs.
Slide clamps until tight.
Cleco top spar flange to skin.
Laid board across trim tab clamps and weighted it to remain flat.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
