Bobs Ten
RV-10
Form Elevator Trim Tabs
1248 - 1348 1418 - 1536
Fabricate brake to finish trim tab trailing edge bends.
Complete the trim tab trailing edge bends, using brake.
Cleco trim tab spar to skin and check for proper shape using clamp blocks, previously fabricated.
Adjust trailing edge bend to yield correct trim tab shape.
Remove clecos and spar.
Fabricate trim tab wedges.
Bend trim tab closeout tabs per plans, using wedges, clamps and plastic mallet.
Cleco spar to skin with wedge and clamp installed.
Match drill closeout tab rivet holes with #30 drill.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
