James and I measured and drilled for the chassis punch, then drilled the corner holes, deburred, sanded, masked, reprimed and mounted the clock.
I had intended to put the clock below the wet compass, but there was about 25 degrees deviation due to iron in the clock. There was no deviation with the clock mounted in the new spot.
