Brief Description: 02 - Avionics tray support bracket
While I had the panel out, I made a bracket to help support the avionics tray under G. The bracket is pinched between the ARINC-429 converter and will allow braces to attach between the firewall reinforcement and the base of the tray. I'll make the braces when I can clearly see what else to deconflict with ... brake lines, wiring conduits etc.
