My goal over this four day weekend was to get all of the wiring connected to the three instrument/switch panels. Another Safari builder suggested that the insulating foam used to protect water pipes might work to protect wire bundles from chafing. They are easy to slip around the bundles and they have easy access if you ever have to add additional wiring. I decided to try his suggestion and wrapped both wire bundles under the center console with the foam tube. I had previously installed wire bundle supports in the floor so attaching to these help firmly anchor the wrapped bundles.
