Started the planning and layout of the center counsole. Center support fabrication was started The center support transitions from the firewall to the instrument panel and supports the top of the console. The plan is to have the side walls of the panel be removable to allow access to the rudder cables, fuel lines, and brake lines. Layout and planning of these subsystems have been started during this work. There will be much fabrication required to complete this step.
