Brief Description: Assemble and start riveting right aileron
After dimpling all parts of right aileron, I eagerly started to assemble and rivet nose ribs to counterweight, then nose rib to spar. I mounted the assembly on L shaped jig made from 2 x 4's with screws through holes in the spar. This was a great idea from other builders....works great. I then clecoed aft skin to assembly and called it a day.
