One of the places where I used the wrong rivets was at the bottom nut plates, I squeezed one the rivets used that the top 4 plates. you see it you drill them out and use the right rivet.
I used my hand squeezer in step 10.
After doing a lot of work on all the rivets for the bulkhead I felt that I could go fast forward. And as you can see in picture 3 I made a mistake but only realized after I had already finished rivetting on 1 side and almost finished the other. Can you see what it is? Well in my next poost you see the right way. If you look carefully you will see that the row of holes right above the top cleco shows no holes underneath. I had switched the 2 brackets so I had to drill out all the rivets and order new ones.
I am getting really good in drilling out rivets :-)
