I took the pictures later but did the work on the 29th.
It shows the main rivets almost finished and now you can see through the holes in first row. I do want to point out one problem I been having. With the longer and thicker rivets when I squeeze them they sometimes move sideways as you can see in picture 2. The head of the rivet and bottom are not in line with each other. So tomorrow I will drill this one out and do it again.
