A good day today working on the fuel system, to the point where I think I'm about done and ready to put fuel in the tanks. Hoses permanently installed included: * Firewall to fuel flow sensor * Fuel flow sensor to mechanical fuel pump * Fuel pump to injector servo inlet * Injector servo outlet to flow divider * Fuel pump overflow * Fuel pressure sensor * Fuel line and breather fittings at both tanks
I also installed the fuel drain plugs in both tanks, and made up cushion clamp assemblies to help support the hoses where necessary.
Next job on the fuel system will be to add fuel to the tanks and carry out fuel sender calibrations, then fuel flow tests. I can't wait.
