Brief Description: 3: Fuel Lines and Other Small Jobs
A few other smaller jobs I worked on today included refitting of the fuel boost pump, commencement of my wiring runs through the centre floor tunnel, and bonding of some cable tie mounts to the floor to be used as anchor points for my wiring loom and brake lines.
I also made up a couple labels for the 0-50 psi fuel pressure and 0-150 psi oil pressure sender units. They both look identical and I'd hate to mix them up.
Fuel pump reinstalled, and the start of my wiring runs
Cable tie mounts glued to the floor
I labelled my fuel pressure and oil pressure sensors, so I know which is which
