A simple little job done tonight after work. I added a connector to the passenger side PTT button wiring, to make it easier to remove the joystick. No need now to take the floor panel off and disconnect the wires at the terminal strip.
I also put my registration mark on the fuselage, in texta, just to see how it will look. I read somewhere that the letters need to be 150mm high, but I've seen plenty of RV's out there with letters smaller than this. I might have to do some more research on this I think.
UPDATE: I did some more research on the CASA website, and found that amateur built aircraft onoy require 75mm high letters. That's much better.
Added a simple connector to the passenger side PTT button wires
