Peters Web Site
Date:  7-1-2018
Manual Reference:  9225501-LOG-05.059
Brief Description:  2: PVC Brake Lines
After removing the front deck assembly then I moved onto something new...the brakes. After studying the drawings for a bit, quite a bit actually, I first drilled the holes in the firewall and mounted the brake fluid reservoir. This sits on the forward side of the firewall and has a penetration through to the cabin for the brake lines. The reservoir also needs a small spacer made up to prevent it from fouling on the angled portion of the stainless firewall. The drawing just shows to use some washers, but instead I made up a proper spacer from some thick aluminium scrap. You can just see it in the first picture below.
With the reservoir mounted I then fitted made up the hoses from the pedals. Nothing very difficult with any of this, just need to pay attention to the detail shown on the drawings.
The brake reservoir mounted to the front of the firewall
