Today I completed termination of the auto-pilot roll servo wiring. I soldered and heatshrinked the power wires and tucked them away inside the main spar space. The network wires I ran through to the rear fuselage where there is a Skyview Network hub. I made the wires off into a 9-pin D shell plug, and plugged into the hub. I also protected the wires by installing into some white sleeving. The wires are sitting loose in the rear fuselage for now. I'll add cable ties and perhaps a cable clamp later, just to make sure they never find their way into any moving parts.
