Peters Web Site
Date:  2-17-2017
Number of Hours:  3.00
Manual Reference:  9225501-LOG-03.043
Brief Description:  Preparing the Rudder Skins
First up tonight I got to the external surfaces of the rudder skins with my soldering iron and removed the blue film from the rivet lines. Then I set about match drilling all the stiffeners to the skins.
The Vans manual suggests that this is easier if you have a table top that you can drill into, so I got myself a 1500 x 900mm piece of 16mm particleboard to put under the skins when drilling. Worked a treat.
After match drilling the instructions say to deburr all the holes before dimpling, however I was sure that I'd previously read in my Standard Aircraft Handbook that when dimpling you shouldn't deburr. I went back to the handbook, and sure enough, it says just that....in two seperate sections. With that in mind I decided to not deburr the holes, and instead went straight into dimpling.
I dimpled all the stiffener rivet holes in the skins with my c-frame, and the stiffener holes with my hand dimple tool. 450 holes drilled and dimpled.
Match drilling all the stiffener holes
Stiffeners cleco'd down and all holes match drilled
Dimpling the very thin rudder skins
