Today I did some more work on the right side cowl hinge pin cover. I shaped the hole to closely match the blank piece (which I painted white to see it easier), then taped the blank in place from the outside, and applied fibreglass to the inside.
I'll leave this for a day or two now to fully harden before going any further. I also need to work out how I'm going to fill all the small gaps I have around the front of the cowl pieces. They haven't mated up as nicely as I'd like, so a bit of work still needs to go into these parts.
No pictures, but I also spent an hour freshening the desicant cannisters screwed into the top spark plug holes of each cylinder.
Trimming the hinge pin cover hole
The white blank piece taped in place
Fibreglass and peel ply is applied to the inside to form a neat recess for the hinge pin cover.
