Mounted the terminal strips called out in Van's wiring plan. The twelve position strip on the port side of the fuselage is no longer available from Radio Shack so it was ordered from Allied Electronics. The strip on the starboard side can accommodate eight connections versus the four position strip shown in the plans. There was room so I added the longer strip just in case additional connections are required.
