Brief Description: Fabricated & installed terminal block and grounds
Had just a little time for the shop today so I fabricated the terminal strip and installed it with three ground posts. The only deviation from Van's schematic is moving the two ground posts right of center so they don't interfere with my parking brake cable. Hopefully, this won't create a problem with wiring but if it does, I will have to solve that problem later.
I checked the ground posts ffor continuity with a LED and a 12V power source. Appears to be functional.
Also added one additional warning light to indicate low oil pressure (< 15 psi). This light will be wired to the Hobbs sensor and will also serve as a reminder that the Master is on at engine shutdown. I have room for perhaps two more indicator lights if the need arises.
