Here is a list of the instruments and radios included in my "plug & play" panel:
1) Trutrak ADI Pilot II Autopilot/ NAV/ Alt Hold (includes servos and harness) 2) Garmin GNC 250XL COM/NAV 3) Narco NAV122 GPS (Complete ILS system) 4) King KT-76 Xponder with Encoder 5) Electronics International VA-1A Volts / Amps (includes shunt) 6) Electronics International FP-5L Fuel Flow/Pressure 7) Electronics International US-8A Ultimate Engine Analyzer 8) Electronics International OPT-1 Oil pressure / Temp 9) UMA Airspeed Marked for RV-8 (temp window for TAS) 10) UMA Altimeter 11) UMA VSI 12) RPM (Set up for Electronic Ignition ie. P-Mags 13) Manifold Pressure 14) Eight day clock with min/sec stop watch 15) Recording G meter 16) RC Allen DG (electric)
Additional Comments:
1) Lighted push button switch to select GNC 250XL or handheld GPS to autopilot 2) All instruments are lighted, either internally or light collar 3) LED dimmer control for Electronic International’s LEDs 4) Digital dimmer power and control pot for all other instrument lights 5) All harnesses, sensors, and probes are included and pre-wired 6) I will have to hook up power leads for each radio/instrument to breakers or fuses, and grounds 7) The fuel flow transducer will have to be installed in my fuel plumbing 8) Probes and engine sensors will require hook-ups 9) All manuals and schematics are included 10) Wiring and harnesses will be labeled to make re-installation easy 11) The Electronics Internatiuonal harnesses are made by EI 12) New mounting hardware for servos included
