WIth this new Fuse from Vans, it came with the holes already setup for the trim system so very little modification needed to install this system. The push tube is the only thing that takes fabrication. Cut it to lenth, drill 3x 1/8 holes and cut the notch for the servo. Installed the Pins and springs and its ready to install. I will not install the servo until I get the wire and the relays.
