I worked the rudder cable idle arm (under pilots knees) go those installed and ready for cables.
This is officially the first cable installed! It is the battery cable ground that I plan on running directly to the engine mount to ground engine and all avioncs. I am testing a wire lable system I found online with www.cableroganizer.com. They are printalbe sheets that come in different sizes. they have the area that it prints on and there is a clear plastic that wraps around the wire and protects the ink. I think this is a great alternative to the hand held printers.
I used a Pnumatic, large wire crimper to crimp the wire down. All wire will be M22759 Mil spec wire when not provided by MFG.
