Brief Description: Setting up Spacers for Elevators
One the VS was set, I movd to the elevator setup.
The Hinges needed to be brough out from where I installed them to just get it set up and hung. The HS needed to be trimmed where the counterballance recesses into it so little by little I trimed it until it was just clear of it.
The control horns do not have holes where the main bolt goes through in the center and there is no instruction on how to dirll it so I will Start by setting the 2 hinges on each elevator so the elevators are straight and the Heims are fully recessed and locked down.
Once they are in place, I will take one off and drill though the hinge into the horn on each side.
