Battery tray is mounted in the aft of the acft due to the IO-360 angle valve and CS Prop. This added weight in the front warrants mounting the battery in the aft location for balance.
The parts were mostly completed, just had to finish drill and rivet them together. The base was screwed to the frame in the bottom of the Fuse via Nutplates.
