Back in June I discovered the wheel alignment of the main gear is not symmetrical and less than desirable for a taildragger, today GAM & PGC helped me more accurately measure the angles, once again, thank you both for your time & input. There is a difference of 2.6 degrees in camber, the left wheel has approximately 0.6 degrees toe-in whilst the right has 0.9 degrees toe-out. That would make for terrible ground handling, the factory is sending some tapered spacers used on the TSI and I am sourcing some more material that may be required for shims. The holiday period now will slow delivery of these items so I don't expect to be able to start sorting this problem until well into the new year.
