Today I was able to install all the wires in the VPX J10 & J12 plugs. My intention is to wire all of the power & ground wires to the components mounted on the mock-up before starting on the interconnects, can bus, etc. I've commenced installing back-up circuits for the radio & propeller power circuits, also the wires from the circuit breakers to the fuel pump switches. The fuel pump circuits will be totally "outside" VPX. The labelling of the wires takes quite some time & lots of the heat shrink tubing, I've used one full roll already. Wires that will go toward the rear fuselage & firewall forward are being coiled & will be attended to later.
