Des' Web Site
Date:  11-26-2023
Number of Hours:  4.00
Brief Description:  Firewall Forward Fuel System
I was able to install two fuel hoses today, the supply from the firewall to the gascolator and from the gascolator to the pumps. Oetiker clamps secure the hoses in place and fire sleeve is installed using stainless steel cable ties with the ends being sealed with silicone tape. I also tightened the brake fluid reservoir hose fittings as access may be limited after all the fuel hoses are installed.
Out of the firewall
Out of the firewall
Down to the gascolator
Back to the pumps
Back to the pumps
