Over the past few weeks I've been busy with other projects however I have managed to get some more wiring done on this project. I've decided not to use the supplied connector block for the integral generator regulator as others on some forums have reported problems when doing so, the regulator is installed but I may need to remove it to connect the remaining 2 wires from the stator when the engine is installed. Components connected now are that regulator, generator 1 fuse, it's disconnect relay, the master contactor, ebus hot battery bus connection, starter contactor, starter engaged annunciator wire, alternator current shunt, battery current magnetic sensor & both fuel pumps including their capacitors. I still need to connect the camera and heater valve actuator and install some fuel hoses before installing the engine. The windscreen bow is still with the painter.
