Today I produced the loom for EGT & coolant connections, the K type thermocouple extension wire is IEC colour coded green & white with green outer sheath. I'll trim the loom to length after the instrument panel is installed. I'll produce more looms from the GEA24 J243 & J244 connectors over the coming days. All these looms will terminate at connectors forward of the firewall.
Additional parameters to be monitored will include airbox temperature, E-bus voltage, 2nd coolant sensor & battery amps from a Hall Effect sensor in addition alternator amps via the shunt.
