Today I was able to complete installing the generator fuses & the relay for the integrated generator. The mating surfaces of the fuse bracket parts were primed & the flush rivnuts installed with JBWeld. The relay mounts onto the firewall at the existing upper screw position of the integrated generator regulator mount, a spacer & longer 6mm screw allow the relay to sit above the level of the insulation blanket. The insulation blanket has been restored to original condition with the help of some spray contact adhesive & aluminium tape.
