Des' Web Site
Date:  5-31-2022
Number of Hours:  8.00
Brief Description:  Luggage Compartment Front Skin & a Table
Yesterday I produced a table of the same height as that used at the paint shop to support the root end of the wings (kindly loaned by PGC, thank you again), having two will hopefully allow both wings to be together in the paint booth, saving time.
Today I drilled holes for mounting the fabric "rear seat pockets" then riveted the luggage compartment front skin in position, it fit surprisingly well with very little reaming of holes required. I'll leave the rear portion of the centre console clecoed in position at this stage in case I need to access the headset jack wiring when the instrument panel is installed. I'll mount the pockets at a later date too.
First rivets in
First rivets in
Left side
Left side
Right side
Right side
