Over the last 2 days I've installed the rudder/brake pedals along with the brake master cylinders. The master cylinder shafts were all adjusted to be the same length which should provide the same resting angle for all pedals, I want the pedals to lean forward at the top as far as possible to avoid riding the brakes. By adjusting the tension of the mount bolts/nuts, all pedals now move freely. Castle nuts with split (cotter) pins were used in lieu of self locking nuts.
