A bit of a mixed bag of work done today. I drilled the holes for the rudder cable exit guides, installed the sound proofing to the luggage compartment rear bulkhead & golf club extension. I then clecoed the top rear skin in position and match drilled the holes in rib 601. This week the factory updated the Service Bulletin (#0010) for this rib, fortunately for me, the replacement rib I received some months ago is of the new design with a material thickness of 0.8mm, that means the service bulletin does not apply to my aircraft. Meanwhile, PGC was swanning around, flying scenic flights along the central NSW coast, what an easy job he has!
