I spent hours today removing the plastic from the baggage compartment skins then deburred them, some plastic almost falls off & other stuff refuses to budge even after heating it in front of the fireplace. Anyway, I have all the parts clecoed in place & have found that I will need to adjust the flanges of the centre cross-member, a part only used in a Sling 2 with the golf club extension, as it will distort the entire structure if I try to rivet it as is. I've also marked where I need to drill the rear cross-member for the golf club extension stringers.
