This morning I alodined the rudder cable adjuster box, the tank temperature was higher than I'm used too and I over did the exposure time, it's VERY yellow! I riveted the external step reinforcing parts in position, as mentioned previously, I won't be installing the steps but I've included this hardware for future owners. I primed the mating surfaces of the rudder cable adjuster box then riveted it into position & I also managed to install the M3 rivnuts for the bottom skin inspection panels, I'll eventually need to seal these hatches to prevent water & exhaust fumes entering the fuselage during flight. Tasks remaining for the rear fuselage include; strobe/trim wiring, tailwheel mount rivnuts, rudder cables install & luggage compartment structure.
