Today I finished this rear section of fuselage. The build manual has a note that says "ensure that the correct sized rivets & bolts are used" however nowhere are the required sizes mentioned!! For rib 8 I used 15mm x 4.8mm rivets & AN3-5A bolts with a thick (standard) washer under the bolt head & a thin washer under the nut.
