Today I disassembled the right aileron, adjusted & reprimed the ribs & then riveted it back together. The lumps & bumps have reduced in magnitude, still not perfect but I'm afraid they will have to do. I installed it on the wing to check the trailing edge alignment & the inboard end was 10-12mm high! I'm not having any good luck with this thing at all. I left all but 2 of the leading edge rivets out so I will be able to adjust the twist out relatively easily but that's now tomorrow's job.
