Commenced the trial fit of the lower wing skins. They fit reasonably well however there will be quite a lot of rib flange adjustments required so as to avoid lumps and some holes don't quite line up but all this is to be expected and will be very time consuming to correct. The lower stringer interfered with the flange of rib 9 so I trimmed the stringer to a matching angle & reprimed the stringer end.
