Spent a couple of hours this morning masking the main spar in preparation of priming the mating surfaces. I also need to determine the routing for the pitot/AOA hoses then mark the appropriate ribs for drilling in addition to marking ribs for the stand-off/mounting points of the electrical wiring. I found a couple of holes need to be drilled in Rib 8 & some brackets also that I forgot to deburr/alodine the pitot probe mount brackets. When I have all this sorted I'll disassemble it, do all the required deburring & painting of the spars etc, assemble the ribs that have multiple components then put it all back together. Quite a bit to do but it will need to wait until I can get back to it in a fews days time.
Nose ribs on
Pitot/AOA probe mount
Rib 8 mounting bracket has more holes than the rib
